a tourer gtc on wheels
GTC wheels on a Tourer
HI,
I've got the standard 17" Elite wheels on the Tourer at the moment and I'm looking to get 18's instead. Unfortunately the only OEM wheels I like (within my budget) are off the GTC. Obviously they have the same stud pattern, but is there anything else I need to consider i.e. spacers or will they just bolt on.  Thanks
Are you sure there the same stud pattern? Some 5 Door J's are 105PCD where as the GTC's are all 115PCD.
(27:th-Jun-2017, 22:39:40)srea064 Wrote: Are you sure there the same stud pattern? Some 5 Door J's are 105PCD where as the GTC's are all 115PCD.
This is what I was lead to believe. Is there anyway to know 100%?
I'm 99% sure the stud pattern on my Tourer is 5x115 as it's the 2.0 cdti. However, I could be wrong. lol Looney
Mine are 5x105
As far as I can tell...
All Astra GTC's PCD are 5x115 pattern.
For 5 door, 1.4, 1.4T 1.6 and 1.3CDTI are 5x105
For 5 Door 1.6T 1.7CDTI and 2.0CDTI are 5x115,
As I've got a 2.0CDTI in theory they should fit unless I've missed something??
(28:th-Jun-2017, 21:41:59)Steveb19111978 Wrote: As far as I can tell...
Yes that's correct they will fit.
If they come with tyres you may want to think about changing them to correct size for 5-door as you may find some rubbing on full lock.
(27:th-Jun-2017, 20:36:49)Steveb19111978 Wrote: HI,
My 2.0 CDTI SRI Tourer has 18" wheels on. I think they were fitted as a option when the car was bought new. No issues with them, apart from the cost of tyres !
Thanks for the help guys, much appreciated.
5 User(s) read this thread:
Perrybug (1:st-Mar-2024, 02:39:44), TrealdUnrem (9:th-Apr-2024, 15:40:26), PonaldUnrem (20:th-Mar-2024, 16:12:02), MichaelEthip (19:th-Nov-2024, 20:01:30), XRumer23pox (1:st-Feb-2025, 03:43:00)
