Read this tonight and must say it's the best excuse yet for speeding!!
http://www.dailymail.co.uk/news/article-...20mph.html
fake news? this is |
Is this Fake News?
27:th-May-2017, 23:44:29
Well that sounds a bit silly haha
28:th-May-2017, 08:44:47
Well you can get engine run on from a diesel and as it doesn't need a spark it could well be true.
The only thing you could try and do in that situation would be to put it in 6th gear and let clutch out quickly in the hope it would stall the engine. Astra-J 2.0 CDTI S/S
28:th-May-2017, 11:34:42
(28:th-May-2017, 08:44:47)Rusty2009 Wrote: Well you can get engine run on from a diesel and as it doesn't need a spark it could well be true. Maybe try turning engine off may work, go into lower gear to try limit it? Not much you can do if it is true Sent from my iPhone using Tapatalk Pro
29:th-May-2017, 07:03:01
(28:th-May-2017, 11:34:42)Jon_es Wrote:(28:th-May-2017, 08:44:47)Rusty2009 Wrote: Well you can get engine run on from a diesel and as it doesn't need a spark it could well be true. Turning the engine off won't work on a diesel. Astra-J 2.0 CDTI S/S
29:th-May-2017, 11:53:14
(29:th-May-2017, 07:03:01)Rusty2009 Wrote:(28:th-May-2017, 11:34:42)Jon_es Wrote:(28:th-May-2017, 08:44:47)Rusty2009 Wrote: Well you can get engine run on from a diesel and as it doesn't need a spark it could well be true. Thought it might of worked with regards to the injectors? Hmm fair enough Sent from my iPhone using Tapatalk Pro (29:th-May-2017, 11:53:14)Jon_es Wrote:(29:th-May-2017, 07:03:01)Rusty2009 Wrote:(28:th-May-2017, 11:34:42)Jon_es Wrote:(28:th-May-2017, 08:44:47)Rusty2009 Wrote: Well you can get engine run on from a diesel and as it doesn't need a spark it could well be true.
29:th-May-2017, 23:05:39
(29:th-May-2017, 23:00:45)Boroboy Wrote:(27:th-May-2017, 22:43:15)srea064 Wrote: Read this tonight and must say it's the best excuse yet for speeding!! Yepp when i came of my bike and couldnt move my legs i didnt think to use my phone that was in my pocket. Sent from my iPhone using Tapatalk Pro
30:th-May-2017, 11:51:39
(29:th-May-2017, 11:53:14)Jon_es Wrote: thought it might of worked with regards to the injectors? Hmm fair enough Switching off the injectors won't work as the engine draws fuel from another source. https://en.wikipedia.org/wiki/Diesel_engine_runaway .
30:th-May-2017, 19:23:41
sorry but if it were me, id dip the clutch and let the engine blow... better than my family dying in a fiery vauxhall mess
31:st-May-2017, 18:41:02
I think he was told to drive at and above 2000rpm down the motorway to clear his dpf but they never said stay in 4th he then held his revs at or over 2000rpm but he went up to fifth or sixth gear that would then be about right at 120mph or well over 100mph basically he did not or does not understand how to drive in low revs and keep his speed low and he has no understanding of the speed limit and got nicked in the proses.
