cleaning interior
Interior Cleaning
Hi guys!
Today I will be talking about cleaning the interior of the car. This is suited for weekly or biweekly cleaning. For more in depth cleaning, take a look at my interior shampoo post which will be posted shortly.
Firstly, remove all rubbish, litter, larger stones and leaves from the vehicle.
Then use a dash brush (pic below) to dust the dashboard, vents, trims and other niggly bits. Allow the dust to fall to the floor.
Use a vacuum with a crevice tool (pic below) to vacuum the floor and seats, the crevice tool is great for the side of the seats and for tight areas.
After this, use a dedicated Interior Cleaner or a mild APC (All purpose cleaner), with a cloth to wipe down all the plastics. If you have a leather cleaner, you can use this to wipe down your leather seats as part of your routine.
I use CarPro Inside, which is a dedicated Interior Cleaner and Leather Cleaner. It also dilutes at 5: 1 (5 parts water to 1 part product).
It foams up lightly to allow longer dwell time, which breaks down the grime and dirt before wiping away with a cloth, leaving behind a refreshing scent.
All that's left is your windows, 2 cloths, one to wipe the window cleaner on, and the other to buff off to a streak free finish.
Top tip - spray air freshener under your mats and seats for longevity.
Happy Hoovering!
[Image: dbdbe8c195f25d738e9134b31b4e352e.jpg]
[Image: 86a426b47df0112eac987dee79e3bc3c.jpg]
[Image: 722b37f49e7e6f3018aad57642031588.jpg]
This customers car, which I did today, was via the same method as above.
[Image: ce1812a9fc66a25ab482d3b27b14606e.jpg]
