Hi all. What are the biggest wheels you can fit to the Astra j 2.0cdti SRI,bear in mind the Astra sri is lower than other models. I have the 225/50/17" atm. I'm currently looking at 235/40/19" do you think they would start to rub with luggage in the boot? These are the ones I'm looking at . https://www.ebay.co.uk/itm/172216806345 they said they would come with 235/40/19 tyres thanks.
Tags |
biggest ?? wheels |
Biggest wheels ??
14:th-Jan-2017, 15:48:57
Hi, I have an sri VX-line and from factory it comes with 235/40/r19 so you'll have no problem putting them on your car, in fact you could probably go for 20" if you're feeling brave.
14:th-Jan-2017, 16:07:37
(14:th-Jan-2017, 15:33:27)Astra VXD Wrote: Hi all. What are the biggest wheels you can fit to the Astra j 2.0cdti SRI,bear in mind the Astra sri is lower than other models. I have the 225/50/17" atm. I'm currently looking at 235/40/19" do you think they would start to rub with luggage in the boot? These are the ones I'm looking at. https://www.ebay.co.uk/itm/172216806345 they said they would come with 235/40/19 tyres thanks. Got a 2010 1.7 cdti sri- currently running 235 40 19" came with the car - thought they were standard... no issues at all..
14:th-Jan-2017, 16:11:54
The Sri vx line comes with that exact size so should be perfect.
14:th-Jan-2017, 16:19:23
14:th-Jan-2017, 16:40:07
those are the vx line wheels in that size. I like the vxr replicas as well in 19 inch.
14:th-Jan-2017, 19:13:41
Those wheels have been put on numerous J's, mostly in Turkey as it has a more established modding scene. The offset is 42 which is fine and width is 8.5J which is the same as genuine 20" VXR alloys.
15:th-Jan-2017, 15:32:00
Mine came with 20" wheels from factory
18:th-Jan-2017, 20:27:32
18:th-Jan-2017, 22:54:04
You can have 20s just lesser profile tyres.
14:th-Feb-2018, 20:50:11
Hi I've got the gtc 2.0 cdti and was thinking of lowering and bigger wheels, anyone know the best comb?
5:th-Aug-2018, 21:20:54
Hi got a set of 19"vxr reps running 235 45 19 on my j 5door could I run 245 35 19 without any rubbing or anything tia
The GTC runs 20" wheels: 8½J x 20 offset 41, tyre 245/40R20 setup.
10:th-Sep-2018, 17:03:14
All the OEM wheel sizes for the Astra J are at bottom of this page.
13:th-Sep-2018, 09:47:45
as said above.. 20" with the right tyres for the rolling diameter..speedo will be out.! not sure if it can be calibrated to suit.
use this site https://www.tyresave.co.uk/tyre-size-calculator/ Sent from my G3311 using Tapatalk |
Who read this thread? |
1 User(s) read this thread: |
Dvaltd (12:th-Nov-2023, 03:19:47) |
