a measuring with tape i person kind need
i need a kind person with a measuring tape
Id like somebody to measure the depth and width of the spare wheel well.
Then can you please give me the interior measurements of the cubby hole on the right hand side in the boot,
Pleaseeeeeeeeeeeeeeeeeeeeeeeeee
Not so simple :-)
The cubby hole: in front 60x270mm at the back 40x250mm depth is 70mm.
Space for the spare wheel is the same (not easy to measure):
depth is 100mm, from left to right at the bottom 590mm at the top 630mm from front to back at the bottom 520mm at the top 560mm.
I used measuring tape so the dimensions are not on 1mm precise.
I hope it is ok for you.
Thsnkyou very much
