10:th-Apr-2014, 08:18:31
rusty can you find me the part number for the rear brake pads for the 5 105 please
| rusty |
rusty
10:th-Apr-2014, 09:04:20
PM me your reg I'll find it quicker lol
10:th-Apr-2014, 09:32:33
Front for 267mm J67
Kit, Brake Pads 13301207 Disc, Front Brake, 276mm DIA 13502044 Rear for 268mm J67 Disc, Rear Brake, 268mm DIA 13502134 Kit, Brake Pads 13319294 13300867 KIT, BRAKE PADS (AXLE SET) (FOR 268MM DIA. BRAKE DISCS, POC J67) (NLS.- USE 13411380) 13502134 DISC, REAR BRAKE, 268MM DIA. (FOR USE WITH POC J67 BRAKE SYSTEM) Would seem that rear pads are the same for your brake system and mine, Astra-J 2.0 CDTI S/S
10:th-Apr-2014, 15:20:30
10:th-Apr-2014, 18:45:37
my be a good idea rusty to add the VM brake kit codes and disc sizes to the how to remove service brake pads. :cool
10:th-Apr-2014, 20:44:11
Are you able get part numbers for the GTC's yet? If so if I supply my registration could you confirm the part number for rear pads and ideally confirm if they are the same as the Insignia. I know the front pads are the same but not sure on the rears.
10:th-Apr-2014, 20:47:39
don't think they have updated the TIS for the GTC as yet
but they should be the same as the j but saying that the VXR has bigger discs and calipers i know the biturbo calipers are much bigger they may be the same as them
10:th-Apr-2014, 21:10:24
John pm me your car reg and look for you.
10:th-Apr-2014, 23:09:45
Rusty does your tis cover the mk5 looking to find out if the rear rewind tool is the same adapter or size of the tool needed for the j
11:th-Apr-2014, 07:44:32
tucpal Wrote:Rusty does your tis cover the mk5 looking to find out if the rear rewind tool is the same adapter or size of the tool needed for the j Look at this Vauxhall Workshop Manuals > Astra H > H Brakes > Rear Wheel Brake > Brake Pads > Repair Instructions > Replace brake pads on rear wheel brake also this Vauxhall Workshop Manuals > Astra J > Brakes > Disc Brakes > Repair Instructions > Rear Disc Brake Pads Replacement Although they have different tool numbers they look the same Astra-J 2.0 CDTI S/S
11:th-Apr-2014, 08:01:36
pcd 32.5mm 6mm pins astra h
so sod it not wasting any money so pliers it is
16:th-Apr-2014, 20:08:18
Astra J GTC, DISCS AND PADS, PCD 5+115
FRONT DISC, 321MM 13502826 FRONT PADS, 13137751 REAR DISCS, 292MM 13502138 REAR PADS, 13300867 ASTRA J 5 DOOR, DISCS AND PADS, PCD 5+105 FRONT DISC, 276MM 13502044 FRONT PADS, 13301207 REAR DISC, 268MM 13502134 PADS SET, REAR 13300867 ASTRA J 5 DOOR DISCS AND PADS 5+115 FRONT DISCS, 300mm 13502051 FRONT PADS, 13301234 REAR DISCS, 292mm 13502137 REAR PADS, 13319294 Astra J VXR, DISCS AND PADS, PCD ???? FRONT DISCS 355mm 13370436 FRONT PADS 13411116 REAR DISCS 314mm 13371163 or 13429575 REAR PADS 13417473
16:th-Apr-2014, 20:13:02
RUSTY can you add the info for the 5+115 300mm
i will add this info in the too the how to for reference good idea may be to merge the thread in the astra gtc section on brakes in to the how to as there is some good info in that thread at some point
17:th-Apr-2014, 07:35:42
add the info mate,
Don't know the PCD of the VXR Astra-J 2.0 CDTI S/S
17:th-Apr-2014, 14:59:33
Cornishtaz fitted VXR wheels to his original GTC. Also the spare wheel I have fits the on the studs of my car just can't get it over rear callipers. The spare came from my Elite. Which reminds me I need to stick it on the for sale page.
