bulbs p21w
P21W bulbs
Anyone recommend led replacement gor the above that are canbus friendly
this is what i use
http://www.hids-direct.co.uk/r580-w21-5w...air-white/
you wont need to worry about the canbus on the GTC it is not on check
Baz you have LED DRL/Sidelights having AFL don't you?
Sorry should have ssid this is for the wifes Corsa. Reverse bulb is deffo on canbus
Would have no idea about the new corsa as to what would wouldn't be error free. I guess if they throw up errors you could see if the 2 loads per bulb works on it.
Ok thanks mate
agreed no idea if they are on the cambus baz
check the corsa forums they will have the answer
Already done but no information on them
if they do put up errors my how to with the loads will work
sure there wired up the same
Another research project for me
it is well worth it
  HID Bulbs for GTC projector headlights eatmybogbrush 1 2,085 7:th-Mar-2025, 08:57:08
  Headlight bulbs WoZLinGToN 3 6,422 26:th-Jul-2018, 13:44:46
Last Post: astra777
  LED Bulbs Daz21 1 4,891 29:th-Mar-2016, 08:20:15
  Reg plate bulbs sheppy1 2 5,605 4:th-Feb-2016, 21:49:14
  headlight bulbs bay 2 5,921 1:st-Jan-2016, 18:57:10
Last Post: Shorty S91
  Fog Light Bulbs (H11 55w) sheppy1 2 5,978 25:th-Nov-2015, 19:27:44
  Change front bulbs DC_ELiTE 10 11,677 25:th-Oct-2015, 13:20:04
Last Post: CRNeo
  LED Canbus No Error Number Plate Bulbs Rusty2009 9 13,118 20:th-Sep-2014, 22:57:19
  Changing Headlight Bulbs And DRLs SI SRI 12 18,316 26:th-Aug-2014, 17:59:50
Last Post: SI SRI
  Fog light bulbs JJ-Yorks 4 8,284 22:nd-Jun-2014, 19:28:27
Last Post: Dicko
