steering wheel conversion switch
Steering wheel Switch Conversion
[Image: vx.o.c.jpeg]
Steering wheel switch LED conversion.
Please see this how-to for how-to remove http://www.vxoc.org.uk/forum/Thread-How-...el-Buttons.
You will need some PLCC-2 the amount needed varies depending on the switch I recommend the ones from this seller on ebay http://www.ebay.co.uk/itm/121277975850?_...EBIDX%3AIT I have had 100's of LED'S from this guy.
So you have the switch
[Image: 1.JPG]
First thing we need to do is open it up, there are 4 clips 2 each side un-clip them with a small screwdriver.
[Image: 2.JPG]
[Image: 3.JPG]
Once you've un-clipped one side you should be able to lift the backing off.
[Image: 4.JPG]
[Image: 5.JPG]
Now carefully you need to remove the PCB board and rubber cover (Not under this are little white plastic lugs which can fall out).
[Image: 6.JPG]
Next step remove the rubber and start your LED conversion. I've marked with a red line which is negative for you.
[Image: 7.JPG]
To get the correct polarity of the new LED you will see the corner is cut this is the negative end, see image below.
[Image: 21.JPG]
As with all electrical how-to's
we except no responsibility for any issues
that could arise all are carried out at your own risk.
If the how-to is followed correctly you should have no issues.
cool well done
  Window switch LED colour change cornishtaz 41 37,509 10:th-Oct-2020, 16:05:52
Last Post: Jinkie
  How-to Instrument Cluster LED Conversion Rusty2009 66 85,293 19:th-Sep-2020, 18:35:05
Last Post: fratiee
  Heater Panel LED Conversion cornishtaz 30 36,725 29:th-Oct-2017, 08:37:18
Last Post: umognog
  How-to Stereo and centre console LED conversion cornishtaz 4 15,977 2:nd-Aug-2016, 08:23:07
  Various switch LED conversion cornishtaz 15 30,878 6:th-May-2016, 21:05:01
Last Post: cornishtaz
N0madd_builds (4:th-Mar-2026, 11:51:52), dongawron (3:rd-Feb-2026, 10:59:04)
