floor flex
Flex floor
Are the flex floor for the 5dr and 3dr compatible?
As far as I know the 3 door is larger
Ok thanks I found this
http://pages.ebay.com/link/?nav=item.vie...GB&alt=web
that's a bargain that. I'm trying to think who has a 3 door with it fitted they could take some measurements and I could compare them with mine.
I could measure my boot if you let me know what measurements you need
Ok I'll grab a pic of mine and add the measurement's on it in a min
Thanks mate
Hopefully this make sense mate.
[Image: DSC_0881.jpg]
I do want to recheck the bottom measurement though.
Measurements are virtually spot on except the one near tailgate which on mine is 2cm wider
Just rechecked the Bottom as I was sure I wrote it down wrong.
the floor is 1010MM (101CM)
the outside to the side trims is 1030MM (103CM)
I've just been checking part numbers and there the same for both. Just the side boot trim is different
Fair enough then I thought there was a slight difference in the boot shape.
I think the actual floor is different
Is there a big difference in the boot side trims just wondering if it'd be possible to modify my present ones
No mate it's just a rectangle cut out where the brackets are.
Cool should be any easy mod.
I'm hoping they post as it's 180 miles each way for me.
  Flex ride shock absorbers and springs ? Raf7007 6 10,474 15:th-Mar-2017, 08:37:48
Last Post: vocky
  Astra 2.0cdti sri puddle passenger floor ricky spanish 6 8,811 25:th-Sep-2015, 12:30:51
Users browsing this thread:
