break kits
Break Kits
Hi all, I'm looking at getting some new breaks, pads and calipers. Mainly because I've got to get new discs and pads anyhow and I might as well go the whole hog. Also because I've just gotten the car 7 weeks back and will get a few year out of it, so the sooner I do it the more use ill have out of it. anyway...
I want to know if anyone can recommend a particular website which will give me the best value for money.
Also if anyone has any recommendations of what i should buy. Its an 59 Astra J (obviously) 1.6 N/A and 19 inch wheels.
A point in the right direction would be a great help. Thank you
Nathan
Why change callipers unless there is something wrong.
You only have a 1.6N/A which isn't a real rocket ship.
Disc and pad wise I would say EBC dimpled and groved with yellow or red stuff pads.
(16:th-Mar-2017, 21:56:43)Rusty2009 Wrote: Why change callipers unless there is something wrong.
Only thinking calipers as my discs are tiny....19 inch wheels and they really do look small, so i presumed if i was getting bigger discs I would need the calipers to match?
Yes you would but TBH I don't see the point of adding bigger discs and calipers there will most likely be other parts that would need changing etc.
Like the break lines etc?
Here they are...I just at think they look too small for the car. I understand it's not exactly quick. Just want something that looks better...
Sent from my E6853 using Tapatalk
Just roughly measured them and the rear is about 240mm and front 270mm...is this standard?
It's BRAKES
Sorry I know it's basic questions just trying to get to grips with it all. Its my first half decent car and trying to look after it
You may find hubs might need changing.
There is a thread in the mechanical section that has the sizes but it sounds about right.
Thank-you Rusty
Users browsing this thread:
