Gunk on oil cap - Printable Version +- VXOC Astra-J/GTC (https://vxoc.org.uk/forum) +-- Forum: Astra-J/GTC Section (https://vxoc.org.uk/forum/forumdisplay.php?fid=5) +--- Forum: Astra-J/GTC Common Problems (https://vxoc.org.uk/forum/forumdisplay.php?fid=22) +--- Thread: Gunk on oil cap (/showthread.php?tid=4314) |
Gunk on oil cap - fezza37 - 19:th-Mar-2019 Hi Guys, Sorry this isn't Astra related, My wife's Corsa has gunk on the oil cap like in the you-tube video below, its not loosing coolant its only driven 3 miles to work and back, i have done an oil and filter change but its still on the cap. in the past couple of years its had the cam belt done the head skimmed, as said its not loosing any water from the bottle, is this OK? what should i do? thanks example of what it looks like below https://www.youtube.com/watch?v=pwgk255nTjA RE: Gunk on oil cap - andyp - 19:th-Mar-2019 Hi take it for a good run warming the engine should burn off the moisture build up and I mean a good run RE: Gunk on oil cap - fezza37 - 19:th-Mar-2019 (19:th-Mar-2019, 17:38:17)andyp Wrote: Hi take it for a good run warming the engine should burn off the moisture build up and I mean a good run Thanks will do RE: Gunk on oil cap - Big Dave2 - 21:st-Mar-2019 Yes, take it for a good old Italian tune. It's the short journeys that is causing it. The oil isn't getting hot enough to boil off any water vapour. |
