Oil sump nut size. - Printable Version +- VXOC Astra-J/GTC (https://vxoc.org.uk/forum) +-- Forum: Astra-J/GTC Section (https://vxoc.org.uk/forum/forumdisplay.php?fid=5) +--- Forum: Astra-J/GTC Technical (https://vxoc.org.uk/forum/forumdisplay.php?fid=20) +--- Thread: Oil sump nut size. (/showthread.php?tid=3711) |
Oil sump nut size. - everson38 - 10:th-Jan-2018 Hey guys Just a quick one. Have a astra J 1.7 gtc diesel. Does anyone know what size socket is need on the sump nut to drain oil. Sent from my SM-G900F using Tapatalk Oil sump nut size. - Iaintruten - 10:th-Jan-2018 Mine on the 2.0cdti was a 13mm socket so would imagine it would be the same. But use a six sided 13mm socket and not a multipoint socket as the sump plugs can be tight and you don't want it slipping and if yours isn't a nut and is a torx it will be a T45 but mine was a hex head so was a 13mm socket will be either or. Sent from my SM-N950F using Tapatalk RE: Oil sump nut size. - everson38 - 10:th-Jan-2018 Hey lain Yeah mine is in the torx family which I hate have why it could just be a normal 6 sided socket is beyond me. Sent from my SM-G900F using Tapatalk Oil sump nut size. - Iaintruten - 11:th-Jan-2018 You could go online and put your reg into euro car parts and see if there sump plugs have the hex head as that is where I get my replacement from which is a hex head, as I always change the sump plug after an oil change. Sent from my SM-N950F using Tapatalk RE: Oil sump nut size. - everson38 - 11:th-Jan-2018 Hey lain that's a good idea actually. I been on euro car oarts and the sump plug that comes up is the one with the torx. But could no ask a favour could you type in your reg and the sump that comes up could u message me the part number so I can find it on the website. Sent from my SM-G900F using Tapatalk Oil sump nut size. - Iaintruten - 11:th-Jan-2018 There's the details for the one I got so if the thread size is the same you will be ok and that will allow you to have the hex head mate. Sent from my SM-N950F using Tapatalk |
