Hi everyone - Printable Version +- VXOC Astra-J/GTC (https://vxoc.org.uk/forum) +-- Forum: Welcome & Site news (https://vxoc.org.uk/forum/forumdisplay.php?fid=3) +--- Forum: Introduction Area (https://vxoc.org.uk/forum/forumdisplay.php?fid=14) +--- Thread: Hi everyone (/showthread.php?tid=2889) |
Hi everyone - Klarko2003 - 26:th-Oct-2016 Hi all New to the site and was wondering if someone could help me. i have a 2012 astra sri 2.0 cdti tourer and car is a bit rough when idling and seen on here some people use a product called pro tec so i went and bought some although i bought the diesel system super clean instead of the common rail system cleaner and just noticed that diesel system super clean wasnt to be used for cars with electronically driven filter regeneration additive tank systems so wondering if i can use this in the astra or not. thanks in advance RE: Hi everyone - tucpal - 26:th-Oct-2016 rough idle on the 2.0cdti is very common i have heard loads of suggestions of what the problem is and i am not convinced by most i believe it is related to the fuel pressure sensor on the fuel rail some have had that replaced with good results after it was changed but some times as you say just a good clean can sort it out RE: Hi everyone - Klarko2003 - 27:th-Oct-2016 (26:th-Oct-2016, 21:54:48)tucpal Wrote: rough idle on the 2.0cdti is very common i have heard loads of suggestions of what the problem is Thanks Tucpal. I get what you mean about the sensor but just been ripped off by a garage for 340 quid so before i even consider taking car to another garage im trying some options cheers RE: Hi everyone - stigeye - 27:th-Oct-2016 A few common causes of rough idle on Astras have been brought up either on here or on facebook. The ones that seem to be most common are like Tucpal said the fuel pressure sensor, suction control valve, MAP sensor, faltering glow plugs, dirty fuel injectors. You could also check your air filter, see if its blocked or needs replacing, and maybe give the MAF sensor a clean while you are at it. I would recommend putting some form of diesel treatment like Wynns Diesel System Cleaner or Magic Bullet Diesel Catalytic Converter Cleaner in your tank when you next fill up, this can help clean injectors etc. There are a number of things you could do yourself if you read through some of the how to's on this site, inc how to service your car and egr, map, maf and throttle body clean. BTW, the Astra doesn't have an additive tank, so if the diesel treatment you purchased is for cars without the additive tank then it will be okay to use. RE: Hi everyone - Klarko2003 - 28:th-Oct-2016 (27:th-Oct-2016, 16:20:12)stigeye Wrote: A few common causes of rough idle on Astras have been brought up either on here or on facebook. The ones that seem to be most common are like Tucpal said the fuel pressure sensor, suction control valve, MAP sensor, faltering glow plugs, dirty fuel injectors. You could also check your air filter, see if its blocked or needs replacing, and maybe give the MAF sensor a clean while you are at it.Thanks stigeye Will have a sdad of all the stuff in the link once my shifts done on Sat cheers. ordered pro tea diesel rail system cleaner additive for the tank plus I have pro tec diesel super system cleaner. put the car in to get serviced 3 weeks ago sm filters and glow plugs shouldbe fine but then again lol I would be best checking them anyway thanks RE: Hi everyone - Klarko2003 - 28:th-Oct-2016 (28:th-Oct-2016, 04:11:24)Klarko2003 Wrote:(27:th-Oct-2016, 16:20:12)stigeye Wrote: A few common causes of rough idle on Astras have been brought up either on here or on facebook. The ones that seem to be most common are like Tucpal said the fuel pressure sensor, suction control valve, MAP sensor, faltering glow plugs, dirty fuel injectors. You could also check your air filter, see if its blocked or needs replacing, and maybe give the MAF sensor a clean while you are at it.Thanks stigeye Typos and predictive text are a pest. will have a look at all the stuff on the link thanks and pro tec additive as i seen on here a lot of people use it RE: Hi everyone - Klarko2003 - 30:th-Oct-2016 Quick update. thanks for the advice guys. however i went ahead and adden pro tec dssc to the tank and after driving only 75 mile on a wee trip yesterday duel carrage/backroad/motorway it sounds and feels to be sorted RE: Hi everyone - stigeye - 30:th-Oct-2016 (30:th-Oct-2016, 06:23:28)Klarko2003 Wrote: Quick update. thanks for the advice guys. however i went ahead and adden pro tec dssc to the tank and after driving only 75 mile on a wee trip yesterday duel carrage/backroad/motorway it sounds and feels to be sorted Good to hear, keep on top of the servicing though, some good treatment in the tank a couple of times a year will help keep things nice and clean. |
