Central locking huge problems - Printable Version +- VXOC Astra-J/GTC (https://vxoc.org.uk/forum) +-- Forum: Astra-J/GTC Section (https://vxoc.org.uk/forum/forumdisplay.php?fid=5) +--- Forum: Astra-J/GTC Technical (https://vxoc.org.uk/forum/forumdisplay.php?fid=20) +---- Forum: Electrical (https://vxoc.org.uk/forum/forumdisplay.php?fid=30) +---- Thread: Central locking huge problems (/showthread.php?tid=2333) |
Central locking huge problems - kosty000 - 30:th-Mar-2016 I own a 2012 Astra j and I have had a lot of problems recently with the car locking itself when the drivers door is moved. It has mainly been an intermittent problem, but now it happens 90% of the time I open the door. It does not matter if the car is: Running, Ignition on, or being unlocked; but when the drivers door is opened, the car will lock and unlock itself multiple times. Its causing me a lot of issues as I have already been locked out twice If anyone else has had similar problems and knows the cause and/or how to fix it, I would be very grateful for some recommendations. RE: Central locking huge problems - bhalay207 - 30:th-Mar-2016 First of all welcome.... Have you checked the wiring to the door? I would also disconnect the battery for an hour to reset the system just in case it's a computer problem. Sent from my LG G4 using Tapatalk RE: Central locking huge problems - Rusty2009 - 31:st-Mar-2016 Welcome. Not heard of this problem before it could many things. Faulty key fob, faulty lock/unlock button on dash faulty module a broken wire a bad ground or just the BCM having a massive freak out. I would try as @bhalay207 says, if that doesn't resolve the issue you could try unplugging the button in the car also try using another key or changing the battery. RE: Central locking huge problems - tucpal - 4:th-Apr-2016 Check the boor looms are locked in position RE: Central locking huge problems - kosty000 - 2:nd-May-2016 thanks for the answers,it was the locking mechanism,just change it whit another ,works just fine RE: Central locking huge problems - plennin - 21:st-Jul-2016 (30:th-Mar-2016, 07:35:27)kosty000 Wrote: I own a 2012 Astra j and I have had a lot of problems recently with the car locking itself when the drivers door is moved. It has mainly been an intermittent problem, but now it happens 90% of the time I open the door. It does not matter if the car is: Running, Ignition on, or being unlocked; but when the drivers door is opened, the car will lock and unlock itself multiple times. Its causing me a lot of issues as I have already been locked out twice Sad to see i'm not the only one with this issue. its really worrying when the car is locked with the engine running... & i'm outside!!!! |
