Polishing a car - Printable Version +- VXOC Astra-J/GTC (https://vxoc.org.uk/forum) +-- Forum: General (https://vxoc.org.uk/forum/forumdisplay.php?fid=8) +--- Forum: General Chat (https://vxoc.org.uk/forum/forumdisplay.php?fid=53) +--- Thread: Polishing a car (/showthread.php?tid=2110) |
Polishing a car - Tonto - 29:th-Jan-2016 Is this car polish machine any good? Has decent reviews and seems ok. I've never polished a car before and I'm not looking to spend much (I know you get what you pay for). May look for same one else where as I know halfords cost more than other places. http://www.halfords.com/webapp/wcs/stores/servlet/ProductMobileDisplay?catalogId=10151&langId=-1&categoryId=165640&productId=918599&storeId=10001 Sent from my iPhone using Tapatalk RE: Polishing a car - Bloopeta - 29:th-Jan-2016 Rubbish mate. If ya want a half decent polisher on a budged, go for kestrel SIM 180 or silverline. Rotary gets best results, but a DA is safer. Alot of people first startin out with a rotary practice on scrap panels first as it can be easy to burn through, especially on swage lines RE: Polishing a car - tucpal - 29:th-Jan-2016 Don't do it waste of money RE: Polishing a car - Bloopeta - 29:th-Jan-2016 That halfords one is nothing more than a toy, you wont achieve any level of paint correction with it, and even applying a glaze they are useless, would get better results by hand Polishing a car - Tonto - 29:th-Jan-2016 Ok thanks guys, links to good but cheap ones then please. Sent from my iPhone using Tapatalk RE: Polishing a car - Bloopeta - 29:th-Jan-2016 Kestral DAS6, Meguiars G220 are decent entry level DA polishers Kestrel SIM 180, or a Silverline silverstorm are the most common entry level rotarys, IMO the Kestrel is the better of the 2, but both are very similar Prices vary from different places, best just to have a search about, and theres always plenty pop up 2nd hand on www.detailingworld.co.uk, especially the DAs as people progress and upgrade to rotary Alot of people start of with a DA, theyre alot safer as harder to burn through, however, if you want to achieve serious paint correction, then a rotary is the way to go. I never bothered with a DA, I went straight to rotary when I first started out. I actually bought a Kestrel SIM 180 myself as my first polisher, then I upgraded to a makita, wasnt cheap, but Ive had it about 8 years now, and its had very heavy use and its never flackered, very smooth, quiet polisher. Think I paid 190 for my makita, but that was on sale, shoulda been closer to 300. I run mine with a 3m backing plate, and im quite fond of the meguiars pads. I like the 3m polish range too Polishing a car - Rusty2009 - 29:th-Jan-2016 I've the megauiers DA my only complaint is the velcro on the pads loses its stickiness after a couple uses. Sent from my iPhone using Tapatalk RE: Polishing a car - Bloopeta - 29:th-Jan-2016 (29:th-Jan-2016, 15:11:48)Rusty2009 Wrote: I've the megauiers DA my only complaint is the velcro on the pads loses its stickiness after a couple uses. Can you not get a 3m one to replace it? Ive had the same 3m backing plate for 10 years, and it sticks brilliantly Polishing a car - Rusty2009 - 29:th-Jan-2016 I was going to look into seeing if I can swap the plate over to the 3". But that's a good idea I'll look into that :-) Sent from my iPhone using Tapatalk RE: Polishing a car - Bloopeta - 29:th-Jan-2016 The 3m arent the cheapest, but the last well, and have a nice feel, not too firm, not too soft Polishing a car - irmartyn - 29:th-Jan-2016 CG Hex Logic pads are decent aswell RE: Polishing a car - Rusty2009 - 30:th-Jan-2016 Been looking today as I deffo want to go down the smaller pad route. I've found these will fit my DA what are peoples thoughts (I do need to order some other bits off autobright) http://www.autobritedirect.co.uk/index.php/flexipads-4-foam-pad-pack-including-da-100mm-backing-plate.html http://www.ebay.co.uk/itm/Meguiars-3-Pads-4-Polishing-Finishing-Cut-Backing-G220-/110667910693?hash=item19c4524e25:g:F3YAAOxyzHxRJI80 RE: Polishing a car - Bloopeta - 30:th-Jan-2016 I have used and still do use the exact same meguiars pads, but the full size ones. I like them, decent pad. Remember when using smaller spot pads, they tend to generate more heat in a more concentated area, so be careful not to burn through. Shouldnt be as bad on a da though RE: Polishing a car - Rusty2009 - 30:th-Jan-2016 They do have another set which would give 5" and 3" http://www.autobritedirect.co.uk/index.php/flexipads-deluxe-da-polishing-pad-and-plate-kit.html The meg has 7" which I think is too big for all the curves on the J, and doing some read most people are saying 5" is the best and they can't understand why megs keep pushing the 7" pads. |
