New LED DRL's showing numerous faults - Printable Version +- VXOC Astra-J/GTC (https://vxoc.org.uk/forum) +-- Forum: Astra-J/GTC Section (https://vxoc.org.uk/forum/forumdisplay.php?fid=5) +--- Forum: Astra-J/GTC (https://vxoc.org.uk/forum/forumdisplay.php?fid=19) +--- Thread: New LED DRL's showing numerous faults (/showthread.php?tid=1231) |
New LED DRL's showing numerous faults - grahamfromoldham - 24:th-Jan-2015 I have fitted (as per Tucpal's 'How to LED DRL error free' guide) but I am having a headache with faults that have thrown up. I have installed the resistors, wiring and Scotchlok clips and LED bulbs correctly. Firstly, the left DRL will light intermittlently but it will light on the sidelight OK. And now the following faults show intermittently: Check left dipped beam lamp Check right dipped beam lamp Check left Daylight running lamp Check right Daylight running lamp When the lights are switched to auto, sidelights and DRL's light OK when its dark. When it is light outside, DRL's do not light in auto mode. (When I turn off the automatic lights feature, the DRL's stay off. I never noticed this with the PIAA bulbs as I thought the DRL's stayed lit no matter what) ANY help appreciated as always, Graham New LED DRL's showing numerous faults - tucpal - 24:th-Jan-2015 what bulbs have you used ? and what load resisters ? as long as you have used two loads on each DRL like this then they are correct New LED DRL's showing numerous faults - grahamfromoldham - 24:th-Jan-2015 Bulbs: http://www.ebay.co.uk/itm/321215617110 Resistors: http://www.ebay.co.uk/itm/171396959845 The only slight difference between my installation and yours is that I have used two Scotchloks for the Negatives instead of putting three wires into one Scotchlok as per your diagram. New LED DRL's showing numerous faults - tucpal - 24:th-Jan-2015 that is fine as long as both negatives from the loads are on the negative from the DRL holder and one positive from each load goes to drl and side light and both DRL,s have teo loads each left and right i think the problem is the bulbs do they dim down for side light if you go to the how to and look at the last few posts from DNT he talks about not all LED bulbs are set up for are set up and shows how this can be corrected http://www.vxoc.org.uk/forum/Thread-HOW-TO-LED-DRL-Error-free-for-the-Astra-J-5-door New LED DRL's showing numerous faults - tucpal - 24:th-Jan-2015 i need to put in the how to too check the led bulbs work correctly and they dim down for side light and drl before you wire the loads in if not the LED will need to have its pins move to the correct positions New LED DRL's showing numerous faults - grahamfromoldham - 24:th-Jan-2015 OK Tucpal, you've given me something to work on. Will have to do it tomorrow as we've lost the light for today in Winsford. Thanks again New LED DRL's showing numerous faults - tucpal - 24:th-Jan-2015 No problem i am sure DNT will enplane the led config New LED DRL's showing numerous faults - tucpal - 24:th-Jan-2015 i will show how to reline the pins on the led later on for you also the loads will cancel the errors for the different wattage bulbs but you will still get errors if the bulb has blown or the led pins on the led are wrong New LED DRL's showing numerous faults - tucpal - 24:th-Jan-2015 CHECK THE LAST POST IN THE LED DRL HOW TO MATE New LED DRL's showing numerous faults - grahamfromoldham - 24:th-Jan-2015 I'm not too sure what is happening but I've just popped out now its dark and have had no faults at all with all lights working correctly. I'll check again the morning but I like the way you have spliced and soldered into the DRL wires, might have to do that myself when the weather warms up. Thanks Tucpal. New LED DRL's showing numerous faults - tucpal - 24:th-Jan-2015 Ok mate if they play up again in the day light it may be the auto lights but hope fully there sorted keep me updated so have a good check tonight and see if all functions work correctly New LED DRL's showing numerous faults - Lewis6317 - 24:th-Jan-2015 Tucpal, does this diagram you done good for cars like mine without auto lights? I ask because i cant remember if you have auto lights Sent from my iPhone using Tapatalk New LED DRL's showing numerous faults - Rusty2009 - 24:th-Jan-2015 It will work on all specs mate Sent from my iPhone using Tapatalk New LED DRL's showing numerous faults - tucpal - 24:th-Jan-2015 Lewis6317 Wrote:Tucpal, does this diagram you done good for cars like mine without auto lights? no i dont have auto lights and i really dont see why this would make any difference New LED DRL's showing numerous faults - grahamfromoldham - 25:th-Jan-2015 Just re-checked the new DRL's and they're refusing to work during daylight. They will work however when I over-ride the auto lights onto manual but when turned back to auto I get the errors. I'm thinking it could be the bulbs? New LED DRL's showing numerous faults - tucpal - 25:th-Jan-2015 no i dont think so if they work correctly on manual and at night then this has to be the sensor for the auto lights i really dont understand why they would not work in auto rusty can you check the wiring and find out whats going on but why do you need auto lights anyway its not hard to turn the lights on when its dark if they work well in Manuel and give no errors you could just leave it like that for now i will have look thou for you and try and work this out New LED DRL's showing numerous faults - Rusty2009 - 25:th-Jan-2015 The only difference in wiring is extra wires from the rain/light sensor to the BCM nothing more. Everything else should work fine. Sent from my iPhone using Tapatalk New LED DRL's showing numerous faults - Rusty2009 - 25:th-Jan-2015 I take it the DRL is not turning on in daylight? Are you getting any errors to check the bulbs? When on put your hand over the light sensor and see if side lights and headlights turn on in auto mode Sent from my iPhone using Tapatalk New LED DRL's showing numerous faults - grahamfromoldham - 25:th-Jan-2015 Hi Rusty. The DRL's do not come on during the day but when I put my hand over the sensor, headlights/sidelights do illuminate OK. Yes, I get the 'Check left and right daylight running lamp' error. However, when my 'normal' DRL bulbs were in up until yesterday, I haven't had any errors or problems at all with the automatic feature. New LED DRL's showing numerous faults - Rusty2009 - 25:th-Jan-2015 I would say it's the bulb then mate if at night you will only get sidelight. Even if you over ride the switch at night the only way to get DRL is to turn them off. Otherwise it's just dipped turn 1 then main beam turn 2. if that makes sense? New LED DRL's showing numerous faults - grahamfromoldham - 25:th-Jan-2015 Yes, I thought as much. I've decided to order the LED's recommended by Tucpal from HIDS Direct to see if this fixes the bug. Thanks for your input Rusty and also Tucpal. Cheers, Graham New LED DRL's showing numerous faults - tucpal - 25:th-Jan-2015 make sure you take the loads off the wires if you are using the standard bulbs as they will blow if the loads are still on the HIDS bulbs will work very well test the bulbs work correct first just ignore the errors for now and when you are happy they dim down and work for DRL then add the loads to cancel the errors. New LED DRL's showing numerous faults - grahamfromoldham - 29:th-Jan-2015 New LED's from HIDS Direct arrived and I'm still getting faults with 'Check right position lamp', 'Check left position lamp'. The problem seems to lie when the lights come on automatically at dusk/dark areas and when I manually turn the headlights on. Sometimes one or the other DRL will go out but happily come back on the day after. If anyone can scratch their head, then as always its appreciated. Could it be the 50w resistors or a relay? New LED DRL's showing numerous faults - Rusty2009 - 29:th-Jan-2015 Just a thought check your rear lights Lewis had this issue we spent ages mucking around in the end it was a rear bulb. I doubt it is as the error would show all the time but worth checking. Sent from my iPhone using Tapatalk New LED DRL's showing numerous faults - tucpal - 29:th-Jan-2015 did you try the LED bulbs with out the loads first if not try this and see how they are for a day also check the bulbs are in the correct way and make sure they are dimming down for side light if not turn the bulbs around in the holders till they do this New LED DRL's showing numerous faults - grahamfromoldham - 29:th-Jan-2015 HI guys, I'll check the rear bulbs but I'm 99% sure I checked them last week. The LED's aren't dimming down so when I get more time on Sunday I'll turn them round and also try them without the loads. Thanks for your suggestions. New LED DRL's showing numerous faults - tucpal - 29:th-Jan-2015 sounds like there the wrong way round New LED DRL's showing numerous faults - tucpal - 30:th-Jan-2015 how did you get on mate ?? New LED DRL's showing numerous faults - grahamfromoldham - 30:th-Jan-2015 Hi Tucpal, I'm up in Oldham for a couple of days to visit family ( I live in Winsford nowadays) but I've managed to grab half an hour earlier to swap the new LED's around half a turn. Before I did, they were very bright and not dimming when I put sidelights/headlights on. After I swapped them, they are dimming and with no faults showing on the 'computer' screen. I only had the engine running for two minutes to check them so the real test will be over the next couple of days. The rear lights are all OK with no bulbs out. I hadn't realised there was a right or wrong way to put these bulbs in. Fingers crossed for now! New LED DRL's showing numerous faults - tucpal - 30:th-Jan-2015 i am sure you will be fine now it is a common mistake and i have now added notes about this to the how to New LED DRL's showing numerous faults - grahamfromoldham - 31:st-Jan-2015 OK, I have driven the car about today, including my journey from Oldham to Winsford and all seems OK with them at last. It was obviously that the bulbs had been put in the wrong way. Doh.....thanks to Tucpal and Rusty!!! New LED DRL's showing numerous faults - tucpal - 1:st-Feb-2015 your welcome |
