JohnL - Replies:
Spare 16inch space saver wheel for a J
Will get a picture but I'm basically wondering what the wheel and tool box would be worth? I've got them from my old J thinking they would fit the VXR but I can't get the space saver over the rear brakes never mind the fronts.
So looking at what the complete setup or just the wheel on it's own would be worth.
John
JohnL - Replies:
Spare wheel for Astra J from 2.0 CDTi [SOLD]
For sale is a spare wheel and tool kit for a Astra J 2.0 CDTi so It's a 16inch spare so I don't believe it will fit the GTC's I know it doesn't fit on the VXR.
The carpet that sits under the spare and the bolt that secures it.
[Image:
http://valver.co.uk/vxr/spare/bolt-and-carpet.jpg ]
Tool kit jack foam and straps
[Image:
http://valver.co.uk/vxr/spare/tool-kit.jpg ]
Spare wheel all secured. It's never been fitted other than me testing to see if it would fit over the rear brak
Kevin - Replies:
Heated Steering Wheel
Did the J ever come with the heated steering wheel option in the UK?
If not, you got to wonder why. I've seen a load of Corsa D's with the SE trim coming through the workshop that have them.
Who knows, maybe the higher up J's have them fitted, but just need the button fitted! Wishfull thinking
Anyone got the option?
JohnL - Replies:
Scale drawing or vector drawing of the 20inch VXR wheel.
We've just got a vinyl cutter in work and fancy sticking some vinyl on the wheel (Mainly just to mess around) but might look in to getting some decent vinyl and might be able knock together other stuff for members.
Wheel painting
Handbrake on one wheel
Hey up guys, hoping someone can point me in the right direction here. My handbrake is only applying onto the nearside wheel. While it was in my local garage (not stealership), the mechanic said it was just sticking. Its only doing it intermittently and wondered if anyone can advise me accordingly please? Cheers
Cheap spare wheel
VXR 20" alloy wheel colour
I have a summitt white vxr with aero kit. I am thinking of changing wheel colour, possibly gloss black or shadow chrome, what do you think. The car comes with diamond cut as standard, but are a pain to keep looking pristine and I am thinking of new colour anyway.
Thanks in advance, oh if anyone has a vxr different colour wheeks from standard then put up some pics.
Safetyman
Steering wheel airbag removal
Has anyone removed the the airbag / horn from the steering wheel?
Had a look on the workshop manual and it says to make a tool to unhook it form the back.
I know to disconnect the battery and wait at least 30 minutes.
How-to Remove old wheel weight sticky pads?
Anyone got any tips on removing the old sticky pads used to stick wheel weights on?
