How to add your photographs to the forum using Photobucket
How to add your photographs to the forum using Photobucket.
You want to include photos into your threads / posts on VX.O.C.
The best way to do this is via an image hosting site, this keeps the sites sever space down and allows you more control over your photos.
I recommend using Photobucket to host your photos, registrati
Noise when using bluetooth for music
I have an eftermarket unit called RoadCommander. It´s like the well known Icebox and also have the big screen and replaces the CD400 unit.
The problem I have is, when using bluetooth for streaming music with my phone. There is a consistent noise. The noise doesn´t change when pressing accellerator pedal or driving at all. It´s consistent and very annoying to listen to. When you turn up the volume it follow´s up and becomes more annoying.
I don´t have AUX input otherwise I would definately b
Using existing dab aerial on android unit ,
Hi guys I got 2015 Astra GTC 2.0 ,
I have upgraded my radio to android head unit , originally I had cd400 plus with dab and usb ,
I know would like to use my existing shark fin antenna to plug in the dab in to my headunit ,when I took my old cd400 unit I didn't find any Dab connector there or anything there was is standard FM antenna ? I have searched the forums and found that there should be a seperate box for the dab and usb unit ,could any one confirm they actually exist and where about are
