how too AMBIENT LIGHT AROUND THE GEAR GATOR
Is it me or are these too cheap?
tucpal - Replies:
how too
fuel filter, too much diesel came out
I filled the car up with diesel and drove to my friends house to do the oil change. After that we attempted the fuel filter by turning the drain screw. However, the diesel just kept on coming out and at just over 2 litres was lost we tightened it back up in the hope some knows why it didn't stop?
I was of the understanding that just the fuel out of the filter housing would come out.
Can anyone please help?
I might be saying too much but...
I can't keep it in any longer - I'm too excited for you. So I've decided I'm going to let you in now on something pretty cool that's happening in the next few days.
It's still very hush-hush so I can't say too much at this stage or I'll get in trouble but I wanted you to know that the next Chris Knott prize draw is soon to be launched and it promises to be the best one yet!
What I can tell you is that it will benefit anyone asking us to quote, between 1 March and 31 May, for a car w
Brakes be protesting too much, shopping list anyone?
After having my local do a clean up job after some squeeling noise from what I thought was the nearside rear.... It's back :( previously the mechanic said the nearside rear showed signs of heat stress and the caliper was mighty tough stuck, to keep and eye on it however...
It's a different wheel this time offside rear, but very obvious blue hue to the disc where it has gotten very hot from the pad rubbing it so I have decided to do a complete pad & disc change, whilst cleaning up the calipers m
Exhaust Gas Temperature too high bank 1
Hey guys
I have a 2013 Astra GTC 2.0 with 62k on the clock. The car has been overheating as it give me the code P2428. the car has had the exhaust temp sensor replaced but still the problem still persists.
Does anyone have any ideas?
Thanks in advance.
Qaranc - Replies:
shark fin how too
Just sorting the parts to fit a calearo fm/am dab shark fin and I read that it will need 2 12 v power supplies. Is there a how too on fitting one of these as I don't fancy messing up looking for 2 12v to connect it to. Because to be honest i have never been any good with electrics and i don't want to make a mistake.
thanks
Wayne
Acond - Replies:
Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too
So 77 000 km behind and 10 years, outer and timing belt not yet changed. Heard that when changing outer belt you have to release the tensioner by taking the right inner wing away etc. Is it so? Any tips. Perhaps time to do timing belt, too? Is it normal job (done V6 several times so basically I can do it but never touched 1.6). What is timing belt change interval? How about water pump? Recommendation for kits?
