DAB retro fit for cars with the CD 400
This is a How for Factory DAB and Integrated FM and Shark Fin Ariel.
for the CD400 with out the Rear Glass Already in Place.
If you have The NAV500 or 600 Go to the How to for The NAV500/600.
So if you have the CD400 Follow Here...
The first thing you are going to have Get is the Tail Gate from a car that has DAB
it will have to be Complete with
DAB retro fit for cars with the cd500 and 600
this is for the NAV500 and 600 that have the FM already in Place
And the Shark Fin on the Roof for the Sat Nav
But do not Have DAB.
If you have the CD400 go to the CD400 DAB how to.
So if you have the NAV500 or 600
And you have the Tabs in Place on the Rear window
then you will find the one for the DAB is a Dummy
just put there in Place to make
How to remove the head unit from the car includes Screen removal
How to remove the head unit from the car.
Includes Screen removal.
Tools needed
* Cross head screw driver
* 7mm socket
*Small slot head screw driver or paper scraper.
Here's how it look to start.
[Image: https://www.vxoc.org.uk/Images/rusty/pos...dio/00.jpg]
1. Remove the non-slip mat.
[img]https://
how too AMBIENT LIGHT AROUND THE GEAR GATOR
This is a how to for the ambient LED light
that goes around the Gear Gator using the Factory LED.
first step........
Is to Remove the Stereo Surround trim
for removal follow this.
How-to remove the head unit
[img]http://www.vxoc.org.
How to remove the center console & EPB switch
How to Remove the Centre Console & EPB Switch.
Yes This is a Big Job...
Step one.........
Remove the Radio surround Trim.
[Image: http://www.vxoc.org.uk/Images/tucpal/How...sole/1.JPG]
[Image: http://www.vxoc.org.uk/Images/tucpal/How...sole/2.JPG]
Step two......
Remove th
online work shop Manuel for the astra j
HERE is a link for the
online Vauxhall workshop Manuel for the Astra j 5 door..
http://vauxhall.workshop-manuals.com/astra-j/index.php
How To remove the front courtesy light
[Image: https://www.vxoc.org.uk/Images/rusty/pos...ight/1.JPG]
1. remove the trim from around the light
[img]http://www.vxoc.org.uk/Images/rusty/post%20images/How-To%20front%20c
The one thing you would do
If you had the money what would be the thing you would want to?
I would love to swim and dive with Dolphins.
Pain in the assignment problem
I purchased a 61 plate 2.0td with 26000 on the clock. Knew it was cat d repaired but drives like a dream. Everything is perfect apart from one thing!
When driving the 'service vehicle soon light comes on' when this happens the start stop doesn't work, cruise control doesn't work and handbrake auto release doesn't work! When the light
My list of cars over the years
I have shown my Mk6 1.4 Sri Turbo in pictures in another thread but here is the list of cars I have had. Sorry no pics at the moment might find a few when I have time.
My car list from when I was about 21.
No.1 Ford Escort 100E side valve 3 Gears. Bought as a, none runner, it needed to be towed home. Took engine out and sorted various valve problems. Then had the chassis welded because of rust. Cost of car £5
No.2 This was a ford 100E van. Engine blew up on 2nd day Got my £10 back
