Water pump £40
http://www.ebay.co.uk/itm/VAUXHALL-WATER...418e561a10
For the following engines on the J
Astra J / Mk6 2010 on - 1.6 Petrol - A16LET
Astra J / Mk6 2010 on - 1.6 Petrol - A16XER
Astra J / Mk6 2010 on - 1.8 Petrol - A18XER (1.8 16 Valve VVT ( Variable Valve Timing ))
For a full list of compatible cars see here
[url]http://www.autovaux.co.uk/product/24405895-water-pump-corsa-vxr-vauxhall-o
Tyre Pump
Hey Guys [SMILING FACE WITH SMILING EYES]
Just a quick one here... Not really important or related to anything I'm doing but wanted to know of the tyre pumps that you guys have with your cars are built into the car (in the boot somewhere) or are separate and you need to plug them into the cig lighter?
Reason I ask is that we had to use one tonight on my old Corsa D and I found out that it's built into the boot side wall! You pop a cover off and run a long pipe from the boot to the tyre and t
Washer pump dead?
Hi guys.
Few weeks back washer pump stopped working.
Took out fuse, cleaned t and put back in. Pump worked.
It's died again, removed fuse, cleaned it and put back in. This time no pump.
I've used one of the spares to see if the fuse was knackered but same thing.
No noise from the pump.
Anyone got any ideas I can look at? I'm no mechanic mind but am happy to give anything a go
Requesting High pressure fuel Pump part number
I have a 2012 Vauxhall Astra MK VI (J) 2.0 CDTI SRI which i bought over a year ago and after owning it 3 months the High pressure diesel pump leaked and had to be replaced which i was fortunate with as it was under warranty. Fast forward to now, i have the car in for a service and it is now leaking AGAIN which i will have to pay out of my own pocket this time.
[color=#ffffff][font=Helvetica, Arial, sans-serif]i found this listi
Moessa - Replies:
Opel Astra J 1.6 A16XER fuel pump & canister failure
Did any body face problem in the fuel pump or canister before???
timing belt and water pump
Hi all. I just want to ask when i should change my timing belt and water pump? I have a gtc 2l cdti with 56000 miles. When do i need to change. Im not sure if it has ever been done as their is no record. Only had car 8 months. Any advice appreciated. I dont want to wait incSe my engine gets ruined. Thanks for your help. Regards
Timing Belt and Water pump change
Does anyone have a how to guide for changing the Timing belt and Water pump on a 2014 Vauxhall Astra 2.0 Diesel?
Engine code A20DTH - 17C48924LBS
Ykrats - Replies:
Which water pump
Which water pump do I need been told there’s 2 for the a20dth engines. Is there an easy way to find out.
Thought the engine code was enough not so.
Any help would be awesome
Coolant pump 1.7 96kw?
Hi there,
Does anybody know if there is any big difference between the 2 sensor water pumps that are on the 1.7 engine . Opel Astra J
The sensor pump from nr crt 8 is very expensive and very hard to find, i'm wondering if i can change it with nr crt 7 and also change the pulley as it's different.
Basically should do the same thing no?
I have attached a photo with the 2 water pumps
Thanks,
1.6 CDTI snapped oil pump chain
Hi New to the forum and after a bit of info, just bought a 2014 1.6cdti with a snapped oil pump drive chain, Is this a common problem and any ideas what causes it, looks a bugger of a job, the owner was quoted £1800 at the garage hence selling it spares or repairs.
any info would be appreciated
cheers
Tim
