Plugs glow in A17DTS
Hello guys.
Im searching for a plugs glow module in a A17DTS motor, because is very different at the rest of the 1.7cdti motors here in Spain (only a few).
I have this model in my Astra and this is very different, and i have not information of this.
I have a problem when start the car by morning, the fail is similar at the alert when a plug glow is broken, but all is ok, and suspect the fail is the module of plugs.
Please, any information is good, diagram, place, suggestions.
i will post
tucpal - Replies:
glow plugs
so at what milage should i change my glow plugs on my 2.0 cdti
anyone done it and tool needed for taking them out
Water Plugs
Hi guys and gals,
Does anyone else have two weird little grommet things under the very bottom of each door frame that are used to sort of let water out of the door when it gets in? My car has them but they always get clogged and stop water getting out which then builds up in the door!
I rang vx to ask for some new ones as mine obviously ain't working but he said they don't sell them and all the cars he had in the dealership didn't even have them bit had a blank hole there instead... Taken mi
spark plugs
does anyone know when the part number changed for the 1.6 n/a spark plugs ?
Been told that part no.55565219 is now replaced with 25193473
mrwup - Replies:
additional USB plugs on dash
Does anyone have installed additional USB plugs on dash near or instead of cigarette lighter (or in other place)? if you do have it done, can you share some pics and some tips?
i am thinking of having 3 port USB hub connected to Android head unit and have extensions (something similar into the ones from below URLs) comming to center panel with fixed plugs. not sure if that will even work though.. but USB hubs are quite cheap (don't see the reason for usb 3 at least for testing if this would
Spark plugs
Glow plugs
The dreaded “service vehicle soon” message came on yesterday and after calling into my local garage they diagnosed a faulty no2 glow plug but they hadn’t got time to fix it. I’ve looked online and found there are 2 types, one with pressure sensors and one without. How do you find out what type my car has?
Thanks in advance
Forgot to add it’s a 2012 2.0 CDTI
chris87 - Replies:
Wrong Spark plugs
I am having exactly the same problem with a 2nd hand Astra as in this thread:
https://www.vxoc.org.uk/forum/Thread-Any...t=55576026
The supplied spark plugs actually seem to be not suitable for the 1.4T engine at all. Their part number is 55565219 and they are chopper plus and not iridium.
Now, one of the supplied spark plugs broke and damaged
andyp - Replies:
sump plugs
Hi now I have changed a lot of oil in my time, and have always renewed the sump plug washer or o ring, but just lately I have come across always renew the sump plug ? when doing an oil change, on web sites and tv shows, any ideas where this is coming from or opinions on the subject, me I think I will stick with renewing just the washer/o ring
1.6 cdti Glow Plugs
[attachment=1152][attachment=1153][attachment=1154][attachment=1155]
[color=#383a3b][size=small][font=segoe ui,helvetica neue,Helvetica,Roboto,Oxygen,Ubuntu,Cantarell,fira sans,droid sans,sans-serif]I have a problem with glow plugs on my 2014 Astra 1.6 CDTI, the multi-function display intermittently comes up ‘Service Vehicle Soon’ so having
