misting up windows
got a problem with misting up windows
post your problems here
the most common cures of this is not knowing you have the aircon on by stealth
pressing the front demist button on to clear the front windscreen
will send more air to the front windscreen but it will also turn the aircon on
even thou the aircon button will not be lit up
so when you turn the heater back to full heat the heater matrix will be freezing cold
and as it heats back up you may get a misting problem with the car
