Engine Control Module
meiki - Replies:
Gate garage remote control
Hi. I am from Czech republic and my English isn't good. Sorry. This forum is best for last Astra.
I would like connect my gate garage remote control to phone button on steering wheel. I can't find right pin on connector. I have not bluetooth, but button MUTE works. I have radio CD400. Gate garage remote control power baterry 12 V.
Have you any idea how to do it? Thank you.
[ATTACH=CONFIG]336[/ATTACH]
[ATTACH=CONFIG]337[/ATTACH]
z8083 - Replies:
climate control
Hello guys i have dual zone climate on my car when i bought it in climate control i had temperature zone at start where i choose if i want single or dual mode but after update i lost that function does anyone about this .
sheppy1 - Replies:
Emission Control Service
So I have a big service on Monday and I've been told I should get an emission control service too which is only an extra £25 of my hard earned money. Now it was explained as a sort of engine flush along with flushing oil out or something before they put fresh oil in... Sounds beneficial! Wondering if you guys would recommend this or is it just a scam?
Change Steering Cruise Control Not Working
I replaced the steering wheel with a more sporty, but also in leather ...
Unlike my old steering wheel cruise control are the keys that where there is a button to activate it where previously remained pressed and activated the white light in the instrument cluster now there are two that the more there is a spy "Lim ".
Before mounting check the wiring and is the exact same same same colors wires and same positions ...
But after it is assembled and tested I realize that I will turn over the whi
sheppy1 - Replies:
Opel Astra Adaptive Cruise Control
@opelastra
Hey mate,
Your Inbox is full. Empty it and I'll reply [SMILING FACE WITH SMILING EYES]
raimon - Replies:
Cruise control not working
Hi guys,
The cruise control is no longer working on my car or is temperamental intermittent problem. It used to be just an occasional thing now it has become more frequent. Basically you turn on cc, light turns white, then you try to engage cruise control it just not working anymore not turning green, tried all sorts of methods on the controls to get it to work but no avail.
I have read up it could be a number of things to cause it. It could be the actual cruise control switch on the steer
Op-com turbo boost control learn
I have a fault code that comes up turbo boost not learned any one had this issue cheers astra j 2.0 cdti tried to learn it on op-com but don't no if I am doing it right
Climate control sensor
Hello, does any one know where the climate control sensor for Astra J sports tourer 2011 is located? Something strange is going on with my climate control. I have to set it up to 26 to start having some slightly heated air inside. No errors on the computer. Thank you in advance for the help.
seat heating control module Fuse
Anyone know what 30amp fuse it’s for the seat heating control module?
Info I got it from,
Battery positive voltage is supplied at all times to the seat heating control module through a 30 A fuse located in the underbonnet fuse block. This voltage is used by the module to supply power to the seat heating elements. Ground for the module is provided at G307.
