Upholstery cleaner. .
Meguiar's Hot Rims All Wheel Cleaner
tucpal - Replies:
alloy cleaner
need a good alloy cleaner recommendations would be appreciated
what do you use and what is best thanks,.
sheppy1 - Replies:
Merlins Blood Wheel Cleaner
Fuel System Cleaner. .
Recently a fuel cleaner was recommended on here and I'm unable to find the thread on here now but I think it was Rusty that recommended the cleaner. .
Topping up oil and DPF cleaner
Hi Guys
I need to top up Motor oil, can i use this to top up Oil from Asda Castrol Magnetec 5W 30 or do i just buy another 5 litre from Vauxhall, as this is different brand and may be slightly different viscosity, which i am not sure.
[color=#141414][size=small][font=Tahoma, Georgia, serif]5w 30 GM dexos 2 oil this is what i used last tim
Best dpf cleaner
Which is best? As In add to fuel tank not remove and clean.
