How-to Remove Airbag Steering Wheel & Buttons
[Image: https://www.vxoc.org.uk/Images/rusty/How...heel/1.JPG]
First thing we need to do is disconnect the battery negative cable, so open bonnet and remove negative cover if fitted then using a 10mm spanner or socket undo and remove the terminal and move it out of the way
Lock/Unlock buttons
Might be a silly or obvious question but:  I have a 2011 astra - it has the lock and unlock button above the CD.
My question - are these buttons meant to be illuminated when activated?  I have it lock automatically when driving off and hear the clunk but nothing on the buttons.
CD400 buttons not working Android head unit install
Hi guys,
I've got a android head unit installed on my Astra SRI 2012 and I cannot make the buttons from the CD400 work. I've got a shop in SE london to do the installation, but it was their first android head unit like that installed on an Astra so I think they missed something.
My unit is similar to the RV5754 [url=https://www.aliexpress.com/item/32811421710.html?spm=2114.search0104.3.1.47a67bffeBwcOL&ws_ab_test=searchweb0_0%2Csearchweb201602_8_10065_10130_10068_10547_319_317_10548_10696_
Retro fit sport and tour buttons
Hello all,
I found a guy over here that can install sport and tour button with limited functions. (Steering wheel and accelerator sensitivity, Auto gearbox shift down etc)
However, upon my checkings I do not have the looms that are necessary. While I was waiting for my buttons to arrive I would like complete the loom on hand so if possible can someone (probably rusty Hi rusty  ) supply me with the pinout for the BCM and the buttons.
PS I tried gme-infotech portal but its name c
steering wheel buttons
Witam, czy mógłby mi ktoś podpowiedzieć jak zaprogramować przyciski sterowania radiem i tempomatem? mam dostęp do sps
